It is currently Thu Oct 22, 2026 6:16 am
 Post subject: 390 boooog fixed
PostPosted: Sat Jul 06, 2002 4:48 pm
A week or so ago someone posted about a bog on a 390 Holley. I was having the same problem and said when I fixed it I would post the results. I have a mild cam, .100 off the head, ported, offy intake, MP headers, 3.50 gears, and auto trans. I tried every thing I knew to do to the carb, nothing worked. The cam (a 252 comp cams cam) shouldn’t need a stall converter but it did. I could feel it up on the converter and bogging off the line. Well it did need a converter, I went to Midwest on Dennis's recommendation and they built me a converter to my engine specks. I was running 17.46 with out the converter, Don’t know yet what it will do with it but it is flying now as compared to before. I predict 16.50 to 16.80. After I got the verter in then I could tune the 390, nothing worked before. Hope this helps someone. It would just barely spin the tires before, now roast them through first.
melam@nxs.net
 Post subject: Re: 390 boooog fixed
PostPosted: Sat Jul 06, 2002 8:14 pm
:Glad to hear the car is running so good. I've been slacking a lot lately...been too hot.
Trysix
Soupitup@msn.com
PostPosted: Sat Jul 06, 2002 8:58 pm
HeeHeeHee!!!!!!
slantzilla@excite.com
PostPosted: Mon Jul 08, 2002 1:35 pm
: A week or so ago someone posted about a bog on
: a 390 Holley. I was having the same problem
: and said when I fixed it I would post the
: results. I have a mild cam, .100 off the
: head, ported, offy intake, MP headers, 3.50
: gears, and auto trans. I tried every thing I
: knew to do to the carb, nothing worked. The
: cam (a 252 comp cams cam) shouldn’t need a
: stall converter but it did. I could feel it
: up on the converter and bogging off the
: line. Well it did need a converter, I went
: to Midwest on Dennis's recommendation and
: they built me a converter to my engine
: specks. I was running 17.46 with out the
: converter, Don’t know yet what it will do
: with it but it is flying now as compared to
: before. I predict 16.50 to 16.80. After I
: got the verter in then I could tune the 390,
: nothing worked before. Hope this helps
: someone. It would just barely spin the tires
: before, now roast them through first.
I am suprised that you need the high stall convertor with that cam. My Barracuda has about the same setup ( except 4spd OD, 3.23 gears) with the 252S cam and I can pull away from a stop at 900rpm without giving the car any gas on level ground. It will lug down to 1000 rpm in 3rd (1:1) and pull away cleanly. I went up a couple of jet sizes from stock on the 390, moved the accelerator pump cam to the more agressive position and use a yellow secondary spring.
Hot-Rod 6
dave.clement@motorola.com
PostPosted: Mon Jul 08, 2002 1:48 pm
: I am suprised that you need the high stall
: convertor with that cam. My Barracuda has
: about the same setup ( except 4spd OD, 3.23
: gears) with the 252S cam and I can pull away
: from a stop at 900rpm without giving the car
: any gas on level ground. It will lug down to
: 1000 rpm in 3rd (1:1) and pull away cleanly.
: I went up a couple of jet sizes from stock
: on the 390, moved the accelerator pump cam
: to the more agressive position and use a
: yellow secondary spring.
I know I didnt think it would need a higher than stock stall but it did i've had V8's with this problem, up aginst the converter, and it felt the same. You know at a stop it was trying to pull through the brakes. I think I need some more carb work now but its 100 percent better. Plenty good enough to drive but I want more.
melam@nxs.net
PostPosted: Mon Jul 08, 2002 4:47 pm
: I know I didnt think it would need a higher
: than stock stall but it did i've had V8's
: with this problem, up aginst the converter,
: and it felt the same. You know at a stop it
: was trying to pull through the brakes. I
: think I need some more carb work now but its
: 100 percent better. Plenty good enough to
: drive but I want more.
What is your idle rpm in gear?
fglmopar@aol.com
PostPosted: Mon Jul 08, 2002 7:24 pm
: What is your idle rpm in gear?
I idle it at about 800 rpm.
melam@nxs.net
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 27 guests
