It is currently Mon Nov 16, 2026 2:00 am
 Post subject: disabling TQ lockup ?
PostPosted: Mon Jan 18, 2010 11:49 am
I read in my Torqueflite Tranny book that the lock up can be disabled in my 998 Trans by installing a shim in the actuator.
Apart from that no data is given as to the size or conf. of said shim.
Anyone ever done this?
Thanks,
Chris
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
PostPosted: Mon Jan 18, 2010 4:39 pm
Why would you want to disable the lockup?
It will not engage for racing and when you are on the highway it improves milage.
PostPosted: Tue Jan 19, 2010 6:04 am
I have considered all the possibilities and I want to try it.
It looks (from the book) like a fairly simple process. Easy to do, and easy to undo if I don't like it.
I am just trying to get an idea for shim thickness etc from anyone who has tried it.
C
PostPosted: Tue Jan 19, 2010 1:43 pm
I Have never done it so I couldnt tell you how. But I don't think getting under the car, dropping the pan, disableing the lockup, putting it back together, and refilling the trans just in case I may like getting worse milage sounds easy to me.
PostPosted: Tue Jan 26, 2010 11:01 am
I've had mileage increase before switching to a non L.U. tranny. that was in my 1st Diplomat, ex squad.
