It is currently Mon Nov 16, 2026 4:35 pm
PostPosted: Tue Feb 09, 2010 11:34 am
Quick question- the title says it all!
Thanks
madam im adam
PostPosted: Tue Feb 09, 2010 11:43 am
Yes, the 904 "family" of transmissions all have the same basic case and rear cross-member mounting location.
There are a lot of changes related to the year of the transmission, the biggest one was the change in 1966, going away from the cable linkage / rear flange set-up and to the mechancal / slip-in yoke version.
There is also the input shaft / converter change in 1968.
Simple answer, a 70 A-body 904 trans will bolt right into a 70 E-body, if already equipped with a 904.
 Post subject: Thanks Doc!
PostPosted: Tue Feb 09, 2010 2:23 pm
madam im adam
Users browsing this forum: Ahrefs [Bot] and 3 guests
