| need help bad https://slantsix.org/forum/viewtopic.php?t=39020 |
Page 1 of 2 |
| Author: | dusterfanatic [ Tue Feb 16, 2010 2:17 pm ] |
| Post subject: | need help bad |
i orderd an engine kit the other day for my slant six now the guy i bought it off of said it was a numbers matching 225 duster i did a vin look up on my car today and it said this car stock was a 198 can someone de-code my block number 2806830-4 thanks |
| Author: | Aggressive Ted [ Tue Feb 16, 2010 2:20 pm ] |
That's a casting number off the side of the block.......need the numbers on the deck right behind/under the alternator. |
| Author: | dusterfanatic [ Tue Feb 16, 2010 2:26 pm ] |
deck # 1e128469 cast # 2843169-3 |
| Author: | Doc [ Tue Feb 16, 2010 2:55 pm ] |
No worry... all the parts in the engine rebuild kit are the same for either a 198 or a 225. DD |
| Author: | dusterfanatic [ Tue Feb 16, 2010 3:11 pm ] |
not the rods and crank |
| Author: | Doc [ Tue Feb 16, 2010 3:24 pm ] |
If you get a "master kit" that includes con rods and crank, then you can turn your 198 into a 225... the block and all the other parts are the same. (Be sure to keep your "core" 198 con rods!) DD |
| Author: | dusterfanatic [ Tue Feb 16, 2010 3:27 pm ] |
thats just it though i want to keep it a perfectly stock and numbers matching |
| Author: | SlantSixDan [ Tue Feb 16, 2010 3:35 pm ] |
Rebuilding the original engine (if yours is in fact the original engine) does not spoil its numbers-matching originality. The rebuild kit does not contain any parts that would change a 198 engine into a 225 engine or the other way around. |
| Author: | dusterfanatic [ Tue Feb 16, 2010 3:48 pm ] |
alright well thanks but i am just looking to find out if its a 198 or 225 |
| Author: | SlantSixDan [ Tue Feb 16, 2010 4:02 pm ] |
The number you posted (1e128469) is not the engine ID number. Check again, carefully. You're looking for a number stamped on a thin surface that faces the sky, directly below #1 spark plug, inboard of the coil mounting bracket. |
| Author: | dusterfanatic [ Tue Feb 16, 2010 4:53 pm ] |
3041 is the only other number on my block but the crank number is 2951265 |
| Author: | Doc [ Tue Feb 16, 2010 5:01 pm ] |
And connecting rod number 2951260 (198 con rod forging number) DD |
| Author: | dusterfanatic [ Tue Feb 16, 2010 5:06 pm ] |
so i do have a 198 |
| Author: | Reed [ Tue Feb 16, 2010 7:15 pm ] |
What is the number stamped on the ledge behind the alternator and under the #1 plug? Any chance your car has an emissions sticker listing the idle speed and plug gap and such? That sticker will give the engine displacement. |
| Author: | dusterfanatic [ Wed Feb 17, 2010 5:05 pm ] |
the connecting rod on one side says AAVV 2B and the other side says 2951250 HYG now the number on the ledg i belive you are talking about says 1E128469 |
| Page 1 of 2 | All times are UTC-08:00 |
