It is currently Sat Jan 03, 2026 9:53 pm
 Post subject: need help bad
PostPosted: Tue Feb 16, 2010 2:17 pm
i orderd an engine kit the other day for my slant six now the guy i bought it off of said it was a numbers matching 225 duster i did a vin look up on my car today and it said this car stock was a 198 can someone de-code my block number 2806830-4 thanks
real american muscle (mopar)
PostPosted: Tue Feb 16, 2010 2:20 pm
That's a casting number off the side of the block.......need the numbers on the deck right behind/under the alternator.
PostPosted: Tue Feb 16, 2010 2:26 pm
deck # 1e128469
cast # 2843169-3
PostPosted: Tue Feb 16, 2010 2:55 pm
No worry... all the parts in the engine rebuild kit are the same for either a 198 or a 225.
PostPosted: Tue Feb 16, 2010 3:11 pm
not the rods and crank
PostPosted: Tue Feb 16, 2010 3:24 pm
If you get a "master kit" that includes con rods and crank, then you can turn your 198 into a 225... the block and all the other parts are the same.
(Be sure to keep your "core" 198 con rods!)
PostPosted: Tue Feb 16, 2010 3:27 pm
thats just it though i want to keep it a perfectly stock and numbers matching
PostPosted: Tue Feb 16, 2010 3:35 pm
Rebuilding the original engine (if yours is in fact the original engine) does not spoil its numbers-matching originality. The rebuild kit does not contain any parts that would change a 198 engine into a 225 engine or the other way around.
PostPosted: Tue Feb 16, 2010 3:48 pm
alright well thanks but i am just looking to find out if its a 198 or 225
PostPosted: Tue Feb 16, 2010 4:02 pm
The number you posted (1e128469) is not the engine ID number. Check again, carefully. You're looking for a number stamped on a thin surface that faces the sky, directly below #1 spark plug, inboard of the coil mounting bracket.
PostPosted: Tue Feb 16, 2010 4:53 pm
3041 is the only other number on my block but the crank number is 2951265
PostPosted: Tue Feb 16, 2010 5:01 pm
And connecting rod number 2951260 (198 con rod forging number)
PostPosted: Tue Feb 16, 2010 5:06 pm
so i do have a 198
PostPosted: Tue Feb 16, 2010 7:15 pm
What is the number stamped on the ledge behind the alternator and under the #1 plug? Any chance your car has an emissions sticker listing the idle speed and plug gap and such? That sticker will give the engine displacement.
PostPosted: Wed Feb 17, 2010 5:05 pm
the connecting rod on one side says AAVV 2B and the other side says 2951250 HYG now the number on the ledg i belive you are talking about says 1E128469
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 21 guests
