It is currently Mon Nov 16, 2026 1:52 am
PostPosted: Sun Feb 28, 2010 4:59 pm
Contributor
I want to replace the nasty looking transmission cooling lines when I swap engines on my '64 Valiant, but I can only find them for a V8.
Does anyone have a source for slant six lines? I'd prefer stainless, but will take whatever I can get.
I've tried the search function, but it's not working.
PostPosted: Sun Feb 28, 2010 5:43 pm
See this post and this one.
Made mine from parts store brake line and fittings. See pics in the slixer's gallery. Seems like the lines for a 904 equipped v8 car would fit without too much massaging...
Are the In/Out fittings on the radiator that different location-wise?
72 dart acquired 12/08 /6,holley2b, mopar perf intake, mopar perf header, cam, built motor,904 finally re-installed, 8.75....still needs sorting out.
99 dakota 318 5 speed reg cab picked up 9/09; Trans finally fixed! woohoo!
PostPosted: Sun Feb 28, 2010 5:58 pm
Not. Totally different between the radiator and the aft end of the engine. You'd have a much easier time adapting different-year slant-6 pre-bent lines, than adapting same-year V8 pre-bent lines. You can get '67+ slant-6 pre-bent lines from Fine Lines, in regular or stainless.
PostPosted: Sun Feb 28, 2010 6:21 pm
Aaah. I was just thinking of either end.
PostPosted: Tue Mar 02, 2010 11:34 am
Contributor
Do you know what the differences are between the '67-up, and a '64?
PostPosted: Tue Mar 02, 2010 1:55 pm
The line going to the rear of the trans has a steeper bend on the 67 & up version. Your 64 has a 45 degree fitting on the trans where the 67 & up has a straight fitting... so the bend in the line is different.
This can be made to work with a little "unbending".
Depending on the radiator, the 67 line may not reach as far to the passenger side... basically, the in / out fittings on the later radiators were closer together.
You may want to take that measurment off your current line and have the supplier check the ones they offer. Again, some careful re-bending will get it to work.
PostPosted: Wed Mar 03, 2010 6:53 am
If you dont mind the looks different scene. Then you can go braided AN style flex lines and fittings.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Mar 03, 2010 2:02 pm
Contributor
Thanks, everyone. I think I'll go with the late model lines and make them work.
