It is currently Sun Nov 15, 2026 11:53 pm
 Post subject: 727 not engaging
PostPosted: Thu Mar 04, 2010 2:37 pm
is it possible theres not enough fluid in the torque converter does it fill up by it self or what cuz i put some fluid in it had it going in reverse for a little but now it wont hmm any help would be apreciated
87 d150 2bbl carb 225
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
89 f450 diseal 4x4 dually 5sp
PostPosted: Thu Mar 04, 2010 2:48 pm
Have you checked the transmission fluid level using the dipstick with the transmission warm and idling in neutral? Also, the use of punctuation makes it much easier to understand what you are saying.
PostPosted: Thu Mar 04, 2010 2:56 pm
sorry yes i have it seems full
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Thu Mar 04, 2010 3:04 pm
What, exactly, have you done, and exactly what symptoms does the transmission exhibit? The torque converter is filled by the pump in the transmission. There are numerous problems that could cause the transmission to work in reverse but not in forward gears. Make sure your shift linkage is adjusted properly, make sure the transmission is full of fluid not just seems to be full, make sure the cooling lines aren't kinked or leaking.
Without more info it is hard to give a more accurate diagnosis. Does the transmission make any noises or just not go into gear?
PostPosted: Thu Mar 04, 2010 7:08 pm
well thank you i think it might need more fluid cuz theres a hole in the floor and we manualy shifted it and it worked at one point now it goes really slow. you can stop it with your hand and when u gass it slows down. I think maybe the kick down band needs adjustment?
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Thu Mar 04, 2010 8:18 pm
ive done new pan new filter new fluid then i swapped in the transmission. could i possibly run the lines off the rad into a bucket an flush it out any gunk?
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Thu Mar 04, 2010 8:23 pm
Wait aminute, you are shifting it manually through a hole in the floor? Are you sure it is being put in the right gear?
PostPosted: Thu Mar 04, 2010 9:18 pm
yes im sure of this and even if it wasnt prd21
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Thu Mar 04, 2010 10:09 pm
6 Pack Dart
It's P R N D 2 L
PostPosted: Thu Mar 04, 2010 10:16 pm
ur right i forgot neutral its late
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Fri Mar 05, 2010 8:57 am
This sounds like a replacement transmission that you "serviced" and installed.
If so, where did the unit come from? Do you have any "history" on the unit? How did it look when the pan was off?
PostPosted: Fri Mar 05, 2010 10:48 am
it all looked clean when it was off the old fluid didnt smell burnt but it did look pretty dark and the original pan on it was rusty.
79 f250 300 v8
97 cavalier z24
83 f150 straight 6
PostPosted: Fri Mar 05, 2010 11:26 am
Crawl underneath, pull the pan, check the bands. If you can't get it to move by adjusting the bands, then it is time to pull it and take it to get rebuilt.
PostPosted: Fri Mar 05, 2010 1:57 pm
Time to get out the factory service manual and follow the troubleshooting guide.
