It is currently Mon Nov 16, 2026 1:03 pm
PostPosted: Wed Apr 07, 2010 11:33 pm
I know the internally balanced small block a904 torque converters will swap so the 4 flexplate to converter bolts line up, but what about the bolt pattern in the back of the cranks where the flexplate bolts up?
Thanks
madam im adam
PostPosted: Thu Apr 08, 2010 7:23 am
5 of 6 bolts in the crank flange match.
PostPosted: Thu Apr 08, 2010 2:42 pm
You will have to oblong one bolt hole, but it will work. That's how I got an SFI approved flexplate on my car. :D
