It is currently Sun Nov 15, 2026 1:06 pm
PostPosted: Thu Mar 11, 2010 2:34 pm
Contributor
I'm converting the ball and trunion joint to a spicer on my '64 Valiant, and also going to a bigger u-joint to match my new 8-3/4 rearend, but I have a couple of questions.
With the rear wheels on the ground and the front end jacked, I measured the dimension between the center of the rear u-joint and the flat surface of the transmission to be 52-1/2". If I have them make a new driveshaft 51-1/2" with the slip-joint seated, will that allow enough movement, or should I plan for more than 1" travel?
Will the 3" tube from the old driveshaft work with the new parts?
The yoke on the 8-3/4 measures 3-1/4". Does anyone know the correct u-joint for that yoke?
My apologies if these are previously answered questions, but I still can't get the search function to work.
PostPosted: Fri Mar 12, 2010 6:06 am
The only question I can answer is the 3" tube will be fine.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
