It is currently Thu Nov 26, 2026 3:53 am
 Post subject: Cold air intake ducts
PostPosted: Fri Mar 12, 2010 11:49 pm
Very nice cold air intake ducts for mounting beside the radiator in the same manner as on the F-body super six, can be found in shops that supply parts for making your own bass reflex speakers for your stereo. The sound outlet ducts, called port tubes, make attachment of a flex hose much easier, and look professional and very nice too. They can be found in lots of sizes, see this or this link for some examples, there are lots of suppliers out there when you know what to look for.
Olaf
Aspenized
PostPosted: Sat Mar 13, 2010 5:47 am
looks like these could make for a clean installation, especially the bolt flange syle.
PostPosted: Sat Mar 13, 2010 11:55 am
I have to correct myself after having been reminded that the F-body air duct doesn't take air from the besides the radiator, but from the inside of the fender behind the left headlight. I oughta know, I have one... :oops:
Instead, take a look at aggressive Ted's solution at this site.
Olaf
Aspenized
PostPosted: Sun Mar 14, 2010 7:57 am
I used the aluminum shields off of drop lights that I got at a hardware store,they were like $4 each,cut the back side off and bent a lip to fit the 3 inch dryer tube.Guzzi Mark
PostPosted: Sun Mar 14, 2010 8:40 am
The bulkhead fitting I am using is from the local hardware store. It is a RV sewer drain fitting. They cost $5.50. The system mounted behind the grill gets good cold ram air flow and really helps when under the hood temps run hot.
