It is currently Sun Nov 15, 2026 7:03 am
PostPosted: Mon Mar 15, 2010 2:29 am
I have a new torque converter from midwest.
How much fluid should I dump into it?
Thnaks!
PostPosted: Mon Mar 15, 2010 3:07 am
About a quart, maybe a little less.
When you fire the motor have the trans in neutral and it will fill anyway.
I always turn the new motor over with the ignition off until it builds oil pressure, that gets the converter filled too.
PostPosted: Mon Mar 15, 2010 12:58 pm
Cool, Sounds like a plan!
PostPosted: Mon Mar 15, 2010 3:17 pm
I would replace the pump seal while your at it, no matter how good it looks. I have had them leak pretty bad just from sitting a few days during an engine swap. It sucks having to do the work twice!
Don't forget to lube the pump bushing and seal too.
PostPosted: Tue Mar 16, 2010 5:49 pm
Thanks another - Fresh 904 Rebuild Everything pre-lubed upon re-assembly.
