| How much to fill the torque converter? https://slantsix.org/forum/viewtopic.php?t=39415 |
| Author: | Greg Ondayko [ Mon Mar 15, 2010 2:29 am ] |
| Post subject: | How much to fill the torque converter? |
I have a new torque converter from midwest. How much fluid should I dump into it? Thnaks! Greg |
| Author: | slantzilla [ Mon Mar 15, 2010 3:07 am ] |
About a quart, maybe a little less. When you fire the motor have the trans in neutral and it will fill anyway. I always turn the new motor over with the ignition off until it builds oil pressure, that gets the converter filled too. |
| Author: | Greg Ondayko [ Mon Mar 15, 2010 12:58 pm ] |
Cool, Sounds like a plan! Greg |
| Author: | AnotherSix [ Mon Mar 15, 2010 3:17 pm ] |
I would replace the pump seal while your at it, no matter how good it looks. I have had them leak pretty bad just from sitting a few days during an engine swap. It sucks having to do the work twice! Don't forget to lube the pump bushing and seal too. |
| Author: | Greg Ondayko [ Tue Mar 16, 2010 5:49 pm ] |
Thanks another - Fresh 904 Rebuild Everything pre-lubed upon re-assembly. Greg |
