It is currently Thu Nov 26, 2026 10:47 am
 Post subject: What am I missing?
PostPosted: Sat Mar 20, 2010 3:10 pm
I bought a Slant Six core with transmission attached and can't get them separated. It looks like the trans is held with only 3 bolts (which is kind of hard to believe...) One is on the passenger side towards the bottom, the other 2 are on the drivers side where the starter would mount on a car. With all 3 bolts out though the engine and trans won't separate. Are there other (hidden???) bolts that I'm not seeing?
Thanks,
Ken
Image[/img]
PostPosted: Sat Mar 20, 2010 3:28 pm
Site Admin
The bolts are in your picture. Remove the ones that go from the transmission into the engine block, and the ones that go into the bellhousing from the engine side.
Make sure you have it close to the floor. That transmission is going to be heavy. Pull the lower splash cover off as well. (The tin on the bottom.)
There are allignment pins in between the whole setup.
CJ
PostPosted: Sat Mar 20, 2010 3:46 pm
On the big bellhousing isn't there a bolt or two inside that you have to remove after the flywheel/clutch come out the bottom? I don't think you can pull the bell with the trans. :?
PostPosted: Sat Mar 20, 2010 4:57 pm
there should be 4 bolts holding transmission to bell housing square type pattern.... then need to remove pressure plate ,flywheel...in behind flywheel is one or two maybe 3 bolts into back of block
PostPosted: Sat Mar 20, 2010 6:15 pm
Just went through this myself, you have to go inside the bell. Really a crappy design.
PostPosted: Sat Mar 20, 2010 7:56 pm
post deleted.
I obviously know nothing.
PostPosted: Sat Mar 20, 2010 8:02 pm
No, on the truck bell the top bolts are inside the bell. The transmission, clutch. & flywheel have to come off so you can get inside to remove them.
PostPosted: Sat Mar 20, 2010 8:18 pm
I hope I didn't come off as being abrasive walpolla, I didn't imply you didn't know anything, it's only that the truck bell is very weird. I've never seen this style myself until a few months ago. Prior to that my response would have been exactly like yours.
 Post subject: Yep...
PostPosted: Sat Mar 20, 2010 9:06 pm
Unless you've had fun with the NP435 and the slant six 11" clutch, you'll never have messed with this... you'll be pulling the tranny, the whole flywheel/pressureplate/etc... before you can completely remove the bellhousing....luckily the versio you have is the "late" bell...the early 60's version is about twice as heavy....
PostPosted: Sat Mar 20, 2010 9:48 pm
That's twisted mind to do this. heh. Is there other of oddball stuff that had to be done in particular way to get at like this?
Cheers, Wizard
