It is currently Mon Dec 29, 2025 10:50 am
 Post subject: Water Neck Interchange?
PostPosted: Tue Mar 23, 2010 5:25 pm
What will swap with the stock Slant water neck??
I want to get one that is "Straight Out" rather than the stock / factrory 90* angle.
Lou, I am getting that summit crossflow for ruster, like you have in the '64 What did you use? (for a water neck?)
I need the straight up water neck to route the upper rad hose to the left side of the engine bay.( for the crassflow rad.)
I need a similar one to get the thing (ruster) running.
I am looking for one on summit now, but there's a lot to choose from.
I have busted 2 older Rads putting on my electric fan, so it's time to upgrade. I was going to get this rad anyway...so might as well spend the dime now.
Thanks all sages for you help!
PostPosted: Tue Mar 23, 2010 6:18 pm
6 Pack Dart
Would the one from a 318 fit??
PostPosted: Tue Mar 23, 2010 6:23 pm
Or a 440?
50 chrysler,54 Plymouth, 64 Valiant conv 4 speed, 66 Valiant V8 wagon, 70 Challenger R/T 440+6 conv 4 speed,80 Colt, 98 Neon ACR,84 Honda V45 Magna
Taking care of 57 300C conv,48 T&C conv. Missing my 67 GTX and 36 Ply coupe
 Post subject: neck
PostPosted: Tue Mar 23, 2010 6:40 pm
The 318 and 440 are the same but the slant takes a smaller T- stat(diameter). Now I don't know what year they changed the small block late model intake but it may be a match for the size of the slant. They are smaller and are stamped steel.May work.
PostPosted: Tue Mar 23, 2010 7:26 pm
Would This work?
http://summitracing.com/parts/DCC-44520 ... refilter=0
it's for the 1979- 93 Small blocks.
My main concern is the Bolt holes lining up and of course the t'stat Registereing in the housing correctly.
PostPosted: Tue Mar 23, 2010 7:39 pm
You could check around a see which engines use the same thermostat gasket-that would let you know what fits.
PostPosted: Tue Mar 23, 2010 7:50 pm
Thanks!
Yep 79 and newer LA Engines are the same as the slant.
78 and older are the bigger 2 1/4 T-stat Housing.
PostPosted: Wed Mar 24, 2010 7:36 am
PM me if this works well as I have the same needs.
Thanks,
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Mar 24, 2010 8:39 am
I bought one at Summit that was supposed to fit the '79 and later bb, but the hole spacing was still too wide. From what I could tell, none of those sold at Summit have the correct hole spacing for a /6. Someone had mentioned in an earlier post a chrome one from Mopar Performance that is supposed to fit, but I haven't located it yet.
Moose
1966 Clark Cortez, Industrial /6
 Post subject: water neck
PostPosted: Wed Mar 24, 2010 4:59 pm
the 79 up small block chrome one from mopar is #P4452025 stamped steel.
PostPosted: Wed Mar 24, 2010 7:30 pm
I went to Pick a part and just kept looking till I found what I needed,pulled mine off a Ford.Didnt pay attention to what model or year,know it had a big heavy hood cause it came down on my head and put me on the ground.Guzzi Mark
PostPosted: Wed Mar 24, 2010 9:02 pm
Yep, '79 up Mopar SB V8 is the one I have.
PostPosted: Thu Mar 25, 2010 1:29 pm
yup Summit charges a hefty price for the thing, but it fits.
The holes are 5/16" on the stamped piece.
I just drilled them out to 3?8" for the slant.
Will work fine.
Probably one from a boneyard LA engine post 79 will work for a lot cheaper!
PostPosted: Thu Mar 25, 2010 4:32 pm
I have to dig around the garage for some comparison but a 2.2/2.5 4cylinder style out let may work. nico
Users browsing this forum: Ahrefs [Bot], Bing [Bot], vitamindart and 2 guests
