It is currently Wed Dec 31, 2025 5:03 am
PostPosted: Thu Jan 14, 2010 2:28 pm
Online
Hi all,
I'm looking at fuel pressure regulators to run 3-4 psi at high flow (280+HP) required for a certain carburetor setup. I hate to spend $150 for a regulator, but might do that if I have to.
Has anyone used these type regs? What can you tell me? Dennis, Doug, Sergio...?
http://www.summitracing.com/parts/HLY-12-804/
I don't see how these "single port" regulators can physically work without a return line. Any ideas?
Thanks,
PostPosted: Thu Jan 14, 2010 2:49 pm
I had one of these. Didn't really care for the size of the orifice that all the fuel flows through, but it worked fine on a 120hp engine with a Weber 32/36 DGV. I'm sure I don't need to tell you how the flowing pressure is always less than the shut-off pressure with a dead-head regulator or how much easier a bypass type regulator is on the fuel pump, but someone else might like to know.
PostPosted: Thu Jan 14, 2010 3:11 pm
6 Pack Dart
That is what I have on my setup.
PostPosted: Thu Jan 14, 2010 3:56 pm
I have this regulator also, only 50-60 bucks, chromed version. heh.
This is dead end regulator.
Cheers, Wizard
PostPosted: Thu Jan 14, 2010 4:35 pm
Lou, I have the same regulator on my car now.
It works because your electric fuel pump will have a small bypass in it.
If it didn't (or the bypass gets clogged) you would blow fuel 3 feet up out of the vent tubes on a 780 Holley. The car will then flood, die, and catch fire.
Not that I have ever experienced this. :shock:
PostPosted: Thu Jan 14, 2010 5:32 pm
Car Model: Toad Wagon
Howdy Lou,
I don't like to complicate systems more than necessary so I run a pump suited to the purpose.
The one I use for my SUs makes 42 gph. Is that enough for your needs?
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Thu Jan 14, 2010 6:55 pm
Is this pump making buzzing/clicking/thudding noise? That's solenoid type that pulses. Not suitable either especially for weber. Rotory type is preferred. I'm asking about that for the reason as I wanted to buy quality type that lasts as long as OEM intank pump types (they are rotory also).
But mine needs to be in range of 3 to 4.5 PSI range. And does NAPA sells one like rotory pump for my needs?
Cheers, Wizard
Lou,thats the one I use.Do not use a liquid filled gauge in the engine compartment,they read differently at different temps.I was constantly adjusting it un till I figured this out.Would fire car up and adjust it to 5.5,then drive to work a check it,2.5.Re adjust,then carb would flood.Liquid gauges heat soak.Guzzi Mark
PostPosted: Thu Jan 14, 2010 9:41 pm
I haven't found a sub 4 lb vane or gearotor pump under $150.00.
The Mr Gasket solenoid job I'm using gives the SUs no grief what so ever, and I believe they're more sensitive to pulse & pressure than the Webers are.
Admittedly my only Weber set's still on the shelf so I'm relying on memory of opinions from road racers back in the '60s on that.
Dick, 225% crazy.
PostPosted: Fri Jan 15, 2010 6:27 am
Online
OK, you guys guessed I'm after a weber setup. Thanks for everyone's thoughts and experiences.
Dick, that pump looks like it has the right specs, but it might be on the edge for my ~280 HP motor. 42 gph is more than people think, if the rating is accurate.
I may just go with a Holley Red pump and the little Holley regulator.
Josh, I agree that is sub-optimal, but the alternative is $300+ for a reg and pump. Will contemplate...
PostPosted: Fri Jan 15, 2010 6:37 am
Lou, my experience is that the Holley blue regulator will not maintain a steady 3-4# but I have had good luck putting two in series, the first one knocks the pump output down to 7-8# and the second one seems to hold 3-4#. My set up is all old stuff when the Holley blue pump was pretty much standard equipment on race cars, now there is much more equipment available.
PostPosted: Fri Jan 15, 2010 8:48 am
Lou,
The only difference I can tell between the Holley Blue and Red pumps is the relief valve spring and the paint color. I used to run a Red Pump without a regulator feeding a Holley carb. Actually, the '66 Dart still runs this setup, I just don't own that car any more! A cheap way to get this done would be the Holley regulator and Red Pump relief spring or even a trimmed Blue Pump relief spring. The other option that's cheap, is quieter and also doesn't offend my sensibilities would be a pair of pulse-type pumps in parallel.
PostPosted: Fri Jan 15, 2010 9:33 am
I used to snag old (70s) Honda Civic electric fuel pumps -- under the back seat, IIRC. Very nice little units. I have no idea what volume they would flow. Honda enthusiasts would probably know.
The pumps from an old Jag XJ6 might be decent as well. I had a series one XJ6 and XJ12.
PostPosted: Fri Jan 15, 2010 10:24 am
Online
Thanks for the additional input. The Red pump already is 7 psi out, so one reg oughtta do it. I could also get a Carter 6 psi 70 gph pump and run the Holley reg down to 3-4.
Seymour, did you ever have trouble sinking the floats on your DCOE's with too high fuel pressure? I think that's what happened when we tried to run these on the V before with a stock pump and no reg. Ran great until it got on the power and 4000RPM+, then bogsville. James L likely had it pegged...
PostPosted: Fri Jan 15, 2010 2:57 pm
I never tried higher fuel pressure with Webers. All the information tells you to keep the pressure low so I just did and it has always worked fine. When I got them I believe they were set up with a lower pressure electric pump and a Filto-Reg set to 3#. A Holley red pump and one regulator would probably work fine. I don't think you will find volume to be a problem.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
