It is currently Sun Nov 15, 2026 10:24 pm
 Post subject: 8 3/4 id
PostPosted: Thu Apr 01, 2010 4:45 pm
hello. have a chance to get a 8 3/4 this weekend and would like to know how to id if its a sure grip... thanks, andy.
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
PostPosted: Thu Apr 01, 2010 5:15 pm
Turn an axle. If the other axle spins in the opposite direction it's not a Sure-Grip.
PostPosted: Thu Apr 01, 2010 6:08 pm
What Joshua Skinner said. If it's a sure-grip: with the rear wheels off the ground, if one rear wheel is turned the other rear wheel will turn in the same direction.
PostPosted: Thu Apr 01, 2010 6:30 pm
couldn't be any easier than that. thanks, andy.
 Post subject: not
PostPosted: Sat Apr 03, 2010 10:51 am
well, not a sure grip. another guy bought a 73 satellite w/o eng trans and some parts for 500 bucks. i could buy the 8.75 assembly from him. what would be a decent price. it looks pretty rough, probably need overhauled. or should i just put my money in the 8.25 in my 84 D100. thanks, andy.
PostPosted: Sat Apr 03, 2010 11:42 am
'73 Satellite could have an 8 3/4, but it's more likely an 8 1/4 if it was a 318 car. Also, they have the iso-clamp rear spring mounting which won't directly fit a pickup even if the pads are mounted in the proper location which they probably are not. The Satellite rear end is also about 1 3/8" narrower than your existing axle.
