| Has any one used this? https://slantsix.org/forum/viewtopic.php?t=39682 |
| Author: | carlherrnstein [ Fri Apr 02, 2010 8:43 am ] |
| Post subject: | Has any one used this? |
Its a Jegs part number 10563 200F on/185F off switch. The first one i got never turned on |
| Author: | Pierre [ Fri Apr 02, 2010 12:09 pm ] |
Test it by dunking it in a pot of boiling water for a min then see if there is any continuity between the output pin and the body. |
| Author: | carlherrnstein [ Fri Apr 02, 2010 2:27 pm ] |
Well I put the new one in and it did the same thing. I am running the coolant at a 50/50 ratio the jug said that it should boil at 275. I put a multi meter on the contact and base shortly after it stoped boiling and got no reading from it. I will try to boil it then try it. thanks Pierre |
| Author: | carlherrnstein [ Fri Apr 02, 2010 3:34 pm ] |
Well,Well,Well nether one of the stupid switches worked so back they WILL go. Can anyone recommend a good switch? |
| Author: | Aggressive Ted [ Fri Apr 02, 2010 3:51 pm ] |
| Post subject: | Radiator Temperature Switch |
I saw the Jeg's switches but figured it would kick on too low..........so I went with the stock GM switch that our auto parts had on hand. The switch is a Wells TS217, 3/8" NPT, two terminal. It was worked perfectly since I installed it. |
| Author: | carlherrnstein [ Fri Apr 02, 2010 6:52 pm ] |
Thanks Ted Would you happen to know the application, so the auto parts flunky will know what to get? |
| Author: | Aggressive Ted [ Fri Apr 02, 2010 10:58 pm ] |
I believe 92 and on Camaro, when they went to electric fans.... |
| Author: | carlherrnstein [ Sun Apr 04, 2010 8:53 am ] |
I went to Columbus yesterday with the intention of returning both switches but, the Jegs clerk talked me into returning one and exchanging the other. Well I don't know if its a fluke or what but it is working at least for now. |
