It is currently Sat Nov 07, 2026 6:37 pm
 Post subject: Has any one used this?
PostPosted: Fri Apr 02, 2010 8:43 am
Its a Jegs part number 10563 200F on/185F off switch. The first one i got never turned on :roll: that was fun coolant boiled all over the place. Any way I put it right next to the thermostat and used Teds diagram to wire it up. When i had the boil over i took the wire off and grounded it and it worked so I'm shur its not my wiring. I'm getting ready to put the replacement switch in now.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri Apr 02, 2010 12:09 pm
Test it by dunking it in a pot of boiling water for a min then see if there is any continuity between the output pin and the body.
PostPosted: Fri Apr 02, 2010 2:27 pm
Well I put the new one in and it did the same thing. I am running the coolant at a 50/50 ratio the jug said that it should boil at 275. I put a multi meter on the contact and base shortly after it stoped boiling and got no reading from it. I will try to boil it then try it.
thanks Pierre
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri Apr 02, 2010 3:34 pm
Well,Well,Well nether one of the stupid switches worked so back they WILL go.
Can anyone recommend a good switch?
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri Apr 02, 2010 3:51 pm
I saw the Jeg's switches but figured it would kick on too low..........so I went with the stock GM switch that our auto parts had on hand. The switch is a Wells TS217, 3/8" NPT, two terminal. It was worked perfectly since I installed it.
PostPosted: Fri Apr 02, 2010 6:52 pm
Thanks Ted
Would you happen to know the application, so the auto parts flunky will know what to get?
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri Apr 02, 2010 10:58 pm
I believe 92 and on Camaro, when they went to electric fans....
PostPosted: Sun Apr 04, 2010 8:53 am
I went to Columbus yesterday with the intention of returning both switches but, the Jegs clerk talked me into returning one and exchanging the other. Well I don't know if its a fluke or what but it is working at least for now. :wink:
85 d-100 HEI 2BBl
06 Toyota Corrola
