It is currently Wed Jun 17, 2026 6:00 am
PostPosted: Tue Mar 30, 2010 1:06 am
Is there a lockstrip available that duplicates/approximates the original?
[And, no, the gm type with the rounded top that shows up all over ebay is not the one I'm looking for!]
Would the Dodge Trucks for those years be a source?
TIA
--Walt Jackson
PostPosted: Tue Mar 30, 2010 6:33 am
No.
Then...no.
No.
PostPosted: Tue Mar 30, 2010 11:01 am
Thanks, Dan.
I was afraid of that.
GM it is, then.
--Walt Jackson
PostPosted: Tue Mar 30, 2010 8:40 pm
Unless it's somehow different, the lockstrip canbe purchased out of Australia.
http://www.pentastarparts.com.au/sunsho ... ail&p=1087
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Mar 30, 2010 9:15 pm
The Australian lockstrip has a smooth/rounded contour, like the GM truck stuff. (the one you've linked to is black, not chrome. Echk, do not want.)
PostPosted: Thu Apr 01, 2010 10:58 am
You may want to check with a local auto glass shop. I've been able to locate some generic strip that way
1972 Plymouth Duster 225
PostPosted: Thu Apr 01, 2010 2:56 pm
hello W L J,
various widths of that lock strip are available in Australia.
I take it that the profile that you want is important?
if you can post a close-up pic of the profile,I will check my local supplier of such stuff,and see how we go.
precise measurements will be helpful too.
regards,Rod :D
PostPosted: Fri Apr 02, 2010 12:02 am
precise measurements will be helpful too. <
This is very generous of you.
I don't have a digital camera, but will see what I can do.
--Walt Jackson
PostPosted: Fri Apr 02, 2010 12:32 am
measurement width wise and trace around the profile,pop it in your scanner,and post a copy of the scan here an option?
W L J wrote:
"This is very generous of you."
---- oh it will cost ya !! :lol: :lol:
regards,Rod :D
PostPosted: Mon Apr 05, 2010 2:36 pm
bump.
Walt,I was only joking about costing you !
If you decided to buy something from over here,well that is a different story.
I can check suppliers if you want. --- free !
regards,Rod
:D
PostPosted: Mon Apr 05, 2010 4:38 pm
Would it help if I sent you a sample of the strip?
If yes, PM me with you address.
Thanks,
--Walt Jackson
PostPosted: Tue Apr 06, 2010 1:47 pm
email sent. failed to deliver - fatal flaw in address it says.
PM sent.
regards,Rod :D
