It is currently Tue Nov 17, 2026 9:16 am
 Post subject: Transmission Lenght
PostPosted: Mon Mar 08, 2010 4:07 pm
I am going to put an a833 OD transmission in my truck that has a \6 727in it am I going to have to change my drive shaft lenght?.If so is it shorter or longer?
How big a job am I in for?
Any pointers will be appreciated!!!!!!!
1984 d150 super 6
1979 aspen super 6
PostPosted: Fri Apr 09, 2010 4:57 pm
i'm on the same mission as you in my 80 d150 with 727 I think the drive shaft yoke is the same but no sure about the lenght. I had to cut a floor out of a truck at the wrecking yard as I have the small hump.
PostPosted: Fri Apr 09, 2010 7:34 pm
dont forget about the ball for the z-bar mounted on frame
