| ballast resistor and ignition relay https://slantsix.org/forum/viewtopic.php?t=39828 |
| Author: | dookdart [ Tue Apr 13, 2010 1:16 pm ] |
| Post subject: | ballast resistor and ignition relay |
Just curious; with the recent failure of a new looking starter relay.....does the ballast resistor effect the relay in any way? I checked with the meter and I'm getting 6v nominal across the coil in the "run" position, so I assume the ballast is working. I'm just trying to figure out why a relatively new relay would fail. thanks |
| Author: | Fopar [ Tue Apr 13, 2010 1:44 pm ] |
Could be just because it's an electical part. |
| Author: | coconuteater64 [ Tue Apr 13, 2010 1:45 pm ] |
Look at the relay carefully. Does it or the packaging say "Made In China" anywhere? |
