It is currently Fri Nov 13, 2026 9:33 pm
PostPosted: Tue Apr 13, 2010 1:16 pm
Just curious; with the recent failure of a new looking starter relay.....does the ballast resistor effect the relay in any way?
I checked with the meter and I'm getting 6v nominal across the coil in the "run" position, so I assume the ballast is working.
I'm just trying to figure out why a relatively new relay would fail.
thanks
PostPosted: Tue Apr 13, 2010 1:44 pm
6 Pack Dart
Could be just because it's an electical part.
PostPosted: Tue Apr 13, 2010 1:45 pm
Look at the relay carefully. Does it or the packaging say "Made In China" anywhere?
