HELP!! Three on tree
https://slantsix.org/forum/viewtopic.php?t=39871
Page 1 of 1
Author:  mrichard [ Sat Apr 17, 2010 1:47 pm ]
Post subject:  HELP!! Three on tree
Ok, so I basically went through several of the linkages on the rods that come off the steering column and tightened them up by adding some washers. Now my car is in reverse where I left it and I can't get it into any other gear. Can't even move the shift lever. Did I overdo the tightening up? Or am I missing something obvious? Thanks for the help. I'm about to undo what I just did but wanted to see if there was anything else to try before I go that route!
Author:  mrichard [ Sat Apr 17, 2010 2:24 pm ]
Ok, I reversed a few of the things I did and it loosened up enough to shift. Too bad. I had it nice and tight! TOO tight! :0
Author:  gato [ Sat Apr 17, 2010 10:15 pm ]
maybe u need to find some washers of a smaller thickness to get it just to ur liking?
Author:  mrichard [ Sun Apr 18, 2010 6:31 am ]
Yeah, good idea, too. I am going to continue to work on it. I think that's the first step, so there is play but not too little.
Author:  Fopar [ Sun Apr 18, 2010 9:06 am ]
Try Dorman for a thin curved washer, I think they are called wave washers.
Author:  gato [ Sun Apr 18, 2010 8:35 pm ]
that oughtta do the trick!
