It is currently Fri Jun 05, 2026 10:09 pm
 Post subject: Carb throttle linkage
PostPosted: Sun Apr 25, 2010 1:49 pm
I need to upgrade my throttle setup. its a non cable type. the set up now, will not allow the carburetor to open up very much. very sloppy. Cable Bound?
Do I need to replace the complete setup including the gas peddle?
in the mail is the Super Sweet Radiator made by Randy......Thanx SlantsixDan.
PostPosted: Sun Apr 25, 2010 5:56 pm
There's no cable to bind in a non-cable type. Perhaps some of your bushings are loose and sloppy (or missing), or maybe the kickdown linkage is screwed up or hitting the exhaust pipe, and blocking full travel. Have you checked?
Pedal assembly, yes.
PostPosted: Mon Apr 26, 2010 3:24 am
Speaking of the kickdown linkage I presume there is some type of retainer for it at the tranny - mine has fallen out and I'm wondering what holds it in - heh.
The car I am restoring is a 1971 Valiant 4 door with a slant 6 - 225 engine.
 Post subject: cable bound?
PostPosted: Mon Apr 26, 2010 5:01 pm
Cable Bound/ = should I go cable? the kickdown has no restrictions or anything like that. i'm wondering if it is the right carburetor on the darn thing
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
