| Wideband o2 location https://slantsix.org/forum/viewtopic.php?t=40017 |
| Author: | hellion_locdogg [ Wed Apr 28, 2010 5:45 pm ] |
| Post subject: | Wideband o2 location |
I have Clifford split headers and want to get a wideband o2 setup. I have dual 2" w an H-pipe. But I am confused as to where to mount the o2 bung. In the H? In the front header or rear header? Or try to find a system that reads to sensors? ,Cliff |
| Author: | terrylittlejohn [ Wed Apr 28, 2010 6:18 pm ] |
the 02 sensor should be in the collector just behind the primaries and low enough so the tip is in the exhaust flow, don`t just weld the nut on the pipe surface, use a step drill to move the 02 sensor in closer.if your h pipe is to far down stream it might not read right with the cooler ex temp.you can get duel 02 sensor kits but they are exspensive, if you weld in 2 bungs and swap the sensor between the 2 it will work for tuning. |
| Author: | hellion_locdogg [ Wed Apr 28, 2010 6:51 pm ] |
I like the idea of 2 bungs, the dual kits are very spendy. Any brand or specific kits you can recommend? ,Cliff |
| Author: | madmax/6 [ Wed Apr 28, 2010 7:46 pm ] |
2 bungs just sounds wrong,,,I put my bung a couple inches past the y.Guzzi Mark |
| Author: | hellion_locdogg [ Wed Apr 28, 2010 8:20 pm ] |
I dont have a y, it is dual to H to dual. ,Cliff |
| Author: | madmax/6 [ Wed Apr 28, 2010 10:01 pm ] |
If ya dont want to spend the money for the 2 bungs.just go off the middle of the h pipe,will get ya close.Mark |
| Author: | terrylittlejohn [ Thu Apr 29, 2010 7:40 am ] |
aem recomends 18in from ex port so with a shorty header the collector is the right spot, if you are running a turbo with higher ex temp`s go 36in back,the 2 bung are 1 for each header not 2 in different location in the same pipe, it work will if you on a tight budget, just shift from side to side to check the tune. |
| Author: | hellion_locdogg [ Thu Apr 29, 2010 2:52 pm ] |
Ya I got that, 1 bung per collecrtor. Welding the rearward bung is going to be a huge PIA. I'll keep you updated, I should get it all together in a couple weeks(paydays).. ,Cliff |
| Author: | terrylittlejohn [ Thu Apr 29, 2010 4:53 pm ] |
yea i know what you mean |
| Author: | hellion_locdogg [ Mon May 03, 2010 4:23 pm ] |
Ok so I got my kit today, I will be installing it this week. I hope to get pics during the install and finish. Can't wait to not have to guess anymore. This is the kit I bought based on reviews. Got it on Ebay for $225. http://www.diyautotune.com/catalog/inno ... p-328.html |
