It is currently Tue Nov 24, 2026 9:16 am
 Post subject: Wideband o2 location
PostPosted: Wed Apr 28, 2010 5:45 pm
I have Clifford split headers and want to get a wideband o2 setup. I have dual 2" w an H-pipe. But I am confused as to where to mount the o2 bung.
In the H?
In the front header or rear header?
Or try to find a system that reads to sensors?
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Apr 28, 2010 6:18 pm
the 02 sensor should be in the collector just behind the primaries and low enough so the tip is in the exhaust flow, don`t just weld the nut on the pipe surface, use a step drill to move the 02 sensor in closer.if your h pipe is to far down stream it might not read right with the cooler ex temp.you can get duel 02 sensor kits but they are exspensive, if you weld in 2 bungs and swap the sensor between the 2 it will work for tuning.
PostPosted: Wed Apr 28, 2010 6:51 pm
I like the idea of 2 bungs, the dual kits are very spendy. Any brand or specific kits you can recommend?
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Apr 28, 2010 7:46 pm
2 bungs just sounds wrong,,,I put my bung a couple inches past the y.Guzzi Mark
PostPosted: Wed Apr 28, 2010 8:20 pm
I dont have a y, it is dual to H to dual.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Wed Apr 28, 2010 10:01 pm
If ya dont want to spend the money for the 2 bungs.just go off the middle of the h pipe,will get ya close.Mark
PostPosted: Thu Apr 29, 2010 7:40 am
aem recomends 18in from ex port so with a shorty header the collector is the right spot, if you are running a turbo with higher ex temp`s go 36in back,the 2 bung are 1 for each header not 2 in different location in the same pipe, it work will if you on a tight budget, just shift from side to side to check the tune. :idea:
PostPosted: Thu Apr 29, 2010 2:52 pm
Ya I got that, 1 bung per collecrtor. Welding the rearward bung is going to be a huge PIA. I'll keep you updated, I should get it all together in a couple weeks(paydays)..
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Thu Apr 29, 2010 4:53 pm
yea i know what you mean :wink:
PostPosted: Mon May 03, 2010 4:23 pm
Ok so I got my kit today, I will be installing it this week. I hope to get pics during the install and finish. Can't wait to not have to guess anymore.
This is the kit I bought based on reviews. Got it on Ebay for $225.
http://www.diyautotune.com/catalog/inno ... p-328.html
'72 4 dr Dart
'63 4 dr Dart
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
