It is currently Fri Jun 19, 2026 11:55 pm
 Post subject: Fuel Filter Element
PostPosted: Mon May 03, 2010 9:36 am
Does anyone have any suggestions or opinions on the different types of fuel filter elements (paper, sintered bronze, or steel mesh)? Thanks.
"You know a car is really yours when you've touched every fastener on it." -David Freiburger
PostPosted: Mon May 03, 2010 10:13 am
Paper is fine for most things, but cannot be cleaned and inspection usually isn't possible. Plastic and glass which would make inspection possible is a safety hazard. Sintered bronze is usually paired with another filter because they don't hold much. They are too limited in capacity for stand alone use. Stainless mesh filters are usually in expensive take-apart filters. They are nice if the proper mesh is used, but relatively expensive.
 Post subject: Re: Fuel Filter Element
PostPosted: Mon May 03, 2010 10:26 am
I always have used the Fram canister type with the replaceable element. It flows well and never ever gives any trouble.
One man's advice
regards, max
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Mon May 03, 2010 10:39 am
Paper, in a metal housing.
