It is currently Fri Nov 13, 2026 9:07 pm
PostPosted: Mon May 10, 2010 8:24 pm
Where is the best place to tap off 12v for a eddy electric choke? right off the ballast resistor??
Also: the eddy instructions say "DO NOT" tap 12v off the coil +.
Why not? what would happen?
PostPosted: Tue May 11, 2010 3:58 am
Coil + generally is not 12v. It is somewhat less, because of the ballast resistor. Also the additional current drawn by the choke t-stat will cause an additional voltage drop through the ballast resistor, meaning even less voltage available at the coil.
PostPosted: Tue May 11, 2010 4:19 am
OK. that kind of drop at the coil can cause a misfire, esp. with an elect. ignition. Makes sense.... thanks!
where to take the power then?
PostPosted: Wed May 12, 2010 3:35 am
Take it from the 12v side(supply) of the ballast resistor, not the side that goes to the coil.
