It is currently Wed Jul 15, 2026 5:04 pm
PostPosted: Thu Aug 08, 2002 5:28 am
Is the splined shaft for the steering column coupling a different diameter between manual and power steering? I know the power steering shaft is 1" shorter than a manual shaft but is the coupling spline on the box also smaller?
Ken_Sharp@bramco.com
PostPosted: Thu Aug 08, 2002 3:44 pm
: Is the splined shaft for the steering column
: coupling a different diameter between manual
: and power steering? I know the power
: steering shaft is 1" shorter than a
: manual shaft but is the coupling spline on
: the box also smaller?
Yes,
The coupling spline is bigger on the manual steering Box. The shafts (power or manual) will accept either coupler.
