| Steering Coupling Shaft Size https://slantsix.org/forum/viewtopic.php?t=4020 |
| Author: | Ken Sharp [ Thu Aug 08, 2002 5:28 am ] |
| Post subject: | Steering Coupling Shaft Size |
Is the splined shaft for the steering column coupling a different diameter between manual and power steering? I know the power steering shaft is 1" shorter than a manual shaft but is the coupling spline on the box also smaller? Ken_Sharp@bramco.com |
| Author: | Doc. [ Thu Aug 08, 2002 3:44 pm ] |
| Post subject: | Re: Steering Coupling Shaft Size |
: Is the splined shaft for the steering column : coupling a different diameter between manual : and power steering? I know the power : steering shaft is 1" shorter than a : manual shaft but is the coupling spline on : the box also smaller? Yes, The coupling spline is bigger on the manual steering Box. The shafts (power or manual) will accept either coupler. DD |
