It is currently Fri Jul 17, 2026 7:19 am
PostPosted: Sun Jun 13, 2010 4:18 pm
Hello, I was wondering if anyone has a part# for the ARP main studs with the provision for mounting the windage tray?
Thanks!
PostPosted: Mon Jun 28, 2010 11:07 am
does anyone know about these or has anyone used them?
Do these even exist?
Do I have to special order them?
PostPosted: Sun Jul 04, 2010 8:06 am
A while back I read you just use the main bolts from the V8 set big block or small block I don't remember tho.
'72 Image Duster /6 with turbo build up
'03 Ram 2500 4x4 w/HEMI 5sp 4:10 posi
My Twister Page
PostPosted: Sun Jul 04, 2010 8:13 am
Mine came with the windage tray.........Seymour would know. Someone was building them up there. Might be in a sticky under engines. I do know if you get them too long they will block off the oil passages. The ones I use have a shoulder and a different size thread on the tray side..........hope this helps.
Seymour goes by exner geek
Regards
MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Sun Jul 04, 2010 8:24 am
I think Maxracer is referring to the bolts that come with Mike Jeffreys windage trays. I am not sure that there are any ARP studs that mount a windage tray, Doug would know if there is.
PostPosted: Sun Jul 04, 2010 8:45 am
Thanks............I couldn't remember. You know I never had a bit of trouble with that tray. Still using it w/ a scraper. Just torque them to the right specs, if you can still get them from Mike.
appreciated Seymour
MaX
1966 barracuda 360
