It is currently Fri Jun 05, 2026 8:02 am
 Post subject: Heat Blanket?
PostPosted: Tue May 25, 2010 2:27 pm
last spring i did a major brake upgrade to my A108 van. disc's up front and 11" drums to the rear.
mounting a larger M/C meant i needed to remove some of the shrouding. a few months b4 that i did a super six upgrade with headers.
these 2 upgrades have left my brake fluid suffering from temperature changes.
where can i get something that will hold up to the heat to try to insulate the M/C and the steel lines?
it's tuff to set up a good pedal for all the temp ranges.
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
2003 Ford Ranger XLT extra cab
1997 Geo tracker(Suzuki Sidekick)
PostPosted: Wed May 26, 2010 5:19 am
http://www.afcoracing.com/tech_pages/fluid.shtml .Check the link for temps for different fluid types.Vans are unique as far as venting engine compartment.You could try a flush of the brake fluid and change to the highest boil point fluid.
