It is currently Mon Dec 29, 2025 7:16 pm
 Post subject: Vaccum ports on a Carter
PostPosted: Thu May 27, 2010 6:18 pm
i just rebiult a Carter 2 barrel. It has alot more ports for vaccume. Anyone have a diagram of where the hose go to the carb??
thanks
PostPosted: Thu May 27, 2010 6:23 pm
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
PostPosted: Fri May 28, 2010 10:31 am
I sure thank you sir....but i couldnt find anything on that...I found a ton of other info i was needing.
If anyone might have some pics of a super six set up with all the lines would be awesome !!!!!
Dan....I seen you posted a thread from a while back about those good exhaust and intake gaskets....can we get those from you or did i read that post wrong???
thanks Dale
PostPosted: Fri May 28, 2010 11:30 am
Gaskets don't come from me. See here. All carb vacuum ports are identified in the linked manuals; if you need info about vacuum routing in the rest of the engine compartment that's a separate matter.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
