| Vaccum ports on a Carter https://slantsix.org/forum/viewtopic.php?t=40403 |
| Author: | DirtyDale [ Thu May 27, 2010 6:18 pm ] |
| Post subject: | Vaccum ports on a Carter |
i just rebiult a Carter 2 barrel. It has alot more ports for vaccume. Anyone have a diagram of where the hose go to the carb?? thanks |
| Author: | SlantSixDan [ Thu May 27, 2010 6:23 pm ] |
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download. |
| Author: | DirtyDale [ Fri May 28, 2010 10:31 am ] |
I sure thank you sir....but i couldnt find anything on that...I found a ton of other info i was needing. If anyone might have some pics of a super six set up with all the lines would be awesome !!!!! Dan....I seen you posted a thread from a while back about those good exhaust and intake gaskets....can we get those from you or did i read that post wrong??? thanks Dale |
| Author: | SlantSixDan [ Fri May 28, 2010 11:30 am ] |
Gaskets don't come from me. See here. All carb vacuum ports are identified in the linked manuals; if you need info about vacuum routing in the rest of the engine compartment that's a separate matter. |
