It is currently Fri Oct 23, 2026 7:47 pm
 Post subject: strocker 170
PostPosted: Thu Aug 15, 2002 7:26 pm
A while back someone wanted to know if you had to use 198 connecting rods to use the 2.2 pistons. Just wondering if it is possible to use stock 170 or 225 rods in the 170 block, with the 2.2 pistons, IF you use the 198 crank, which would stroke it for the extra length.
duifhuis@ultranet.ca
 Post subject: Re: Stroker 170
PostPosted: Thu Aug 15, 2002 10:41 pm
: A while back someone wanted to know if you had
: to use 198 connecting rods to use the 2.2
: pistons. Just wondering if it is possible to
: use stock 170 or 225 rods in the 170 block,
: with the 2.2 pistons, IF you use the 198
: crank, which would stroke it for the extra
: length.
Yes, I have built a 198 "low block" and that's a fun little engine. (mine was 3.5 bore, = 209 cubes
You need use the 170 con rods and do a bunch of block and crank grinding work to get the crank's counterweights to clear the block, but it can be done. This is covered in more detail in the "stroking" article.
<A HREF="http://www.slantsix.org/articles/stroking/stroking.htm">http://www.slantsix.org/articles/stroking/stroking.htm</A>
Stroking Article
Users browsing this forum: No registered users and 22 guests
