It is currently Mon May 25, 2026 2:55 pm
 Post subject: my slant still stalling
PostPosted: Wed Jun 16, 2010 5:45 pm
ok i changed all my gaskets .chekd all my vacuum i followed the line to my master cylinder can? dont quiet kno the name. i found that the seal of thye master cylinder to the can is not sealed.is this major?shoulod i change the whole can or do my best to seal it??
dodge b150 4x4 225 supersix,8 inch lift26605_1315915292058_1055981099_30764636_7102626_n
PostPosted: Wed Jun 16, 2010 6:38 pm
Power brake booster???You need to seal ALL vacume leaks to get good idle and no stalling.
PostPosted: Wed Jun 16, 2010 9:50 pm
I'm glad you figured that out. I think you are right on.
Sam
PostPosted: Wed Jun 16, 2010 11:02 pm
6 Pack Dart
You should be able to replace the grommet on the booster. If you pull on the check valve (the part the hose goes on) you can pull it off the booster and then you can work off the grommet.
PostPosted: Thu Jun 17, 2010 6:46 pm
THANKS i sealed the leak now its running ok .i still have a studder and a whistle?.it sounds like it wants to stall sometimes. wont stall, but i was wondering if this could be the timing change.?? im trying to make it to bike week.ends sunday hopin to go show the van at the ralley
Users browsing this forum: Bing [Bot], Google [Bot], morsim and 2 guests
