| ballast or no ballast https://slantsix.org/forum/viewtopic.php?t=40669 |
| Author: | coachjay [ Wed Jun 16, 2010 10:06 pm ] |
| Post subject: | ballast or no ballast |
| Author: | emsvitil [ Wed Jun 16, 2010 10:14 pm ] |
I use the 3.0 Pertronix coil with the pertronix ignition and NO ballast... No problems. And NO ballast to go bad. BTW, I talked to a Pertronix engineer about having the 1.5 and ballast vs the 3.0 and NO ballast.... He said he would use the 3.0 and NO ballast with their ignitor. |
| Author: | coachjay [ Wed Jun 16, 2010 10:27 pm ] |
wow thanks Ed,ok so the 4 wires at the old ballast just butt connect them together.and red wire to + and black wire - at coil on the new 3.0 |
| Author: | Aggressive Ted [ Thu Jun 17, 2010 11:20 am ] |
Yes, that is correct! I run the same setup, a 3 ohm Pertronix 60,000 volt HEI type HV coil but still using a old orange Mopar ECU and stock 74 distributor. Just jumper or solder the wires together. |
