It is currently Fri Nov 13, 2026 11:38 pm
 Post subject: coil ?
PostPosted: Thu Jun 17, 2010 10:25 pm
God bless . i was wondering my car smokess and it smells like gas . i changed the sparkplugs and and noticed that they where carbon coated with a black dust which you can wipe out ? wires are new sparkplugs as well will the coil defective or change to a hotter sparkplug i got stock heat range
PostPosted: Fri Jun 18, 2010 7:22 pm
Sounds like your running rich, what kind of carb do you have?
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Fri Jun 18, 2010 9:48 pm
holly 1920 single barrel
PostPosted: Sat Jun 19, 2010 8:54 pm
I had a holley 1920 that was a remanufacture that was waaaay rich . The power enrichment system was stuck open all the time.
you might try to rebuild it
good luck
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sun Jun 20, 2010 6:50 am
Yes, those are very simple carbs to rebuild. I get 25+ mpg from mine with a #56 jet.
