| coil ? https://slantsix.org/forum/viewtopic.php?t=40681 |
| Author: | guillermo [ Thu Jun 17, 2010 10:25 pm ] |
| Post subject: | coil ? |
God bless . i was wondering my car smokess and it smells like gas . i changed the sparkplugs and and noticed that they where carbon coated with a black dust which you can wipe out ? wires are new sparkplugs as well will the coil defective or change to a hotter sparkplug i got stock heat range |
| Author: | carlherrnstein [ Fri Jun 18, 2010 7:22 pm ] |
Sounds like your running rich, what kind of carb do you have? |
| Author: | guillermo [ Fri Jun 18, 2010 9:48 pm ] |
holly 1920 single barrel |
| Author: | carlherrnstein [ Sat Jun 19, 2010 8:54 pm ] |
I had a holley 1920 that was a remanufacture that was waaaay rich . The power enrichment system was stuck open all the time. you might try to rebuild it good luck |
| Author: | Aggressive Ted [ Sun Jun 20, 2010 6:50 am ] |
Yes, those are very simple carbs to rebuild. I get 25+ mpg from mine with a #56 jet. |
