It is currently Fri Nov 13, 2026 9:34 pm
 Post subject: Weird box on my 63 ....
PostPosted: Fri Jun 18, 2010 12:55 pm
What is this thing ???
PostPosted: Fri Jun 18, 2010 1:04 pm
it is a type of electronic ignition. used a lot on lawn mowers, chain saws and even some cars too. most common along with the others is a motor cycle. capacitive discharge is what it uses to discharge current output to fire the spark plugs.
mostly that's what wiki said. someone else might know more about it.
is it something you just found laying around?
PostPosted: Fri Jun 18, 2010 1:17 pm
No , it was mounted on the latest 63 Valiant I bought , I replaced it with the HEI system( coil and mount from a 97 GM truck ) .
Steve
PostPosted: Fri Jun 18, 2010 1:29 pm
ah that makes sense, that can be found on cars sometimes also. good that you replaced though i think. it has a short charging time and sometimes isn't enough to make reliable ignition. good to hear you got hei on your car thats definately nice to have
PostPosted: Fri Jun 18, 2010 1:38 pm
