It is currently Tue May 26, 2026 9:05 am
 Post subject: trw forged pistons
PostPosted: Sat Jun 19, 2010 5:05 am
has anyone had experience with older trw forged pistons? my machine shop found someone with some laying around and they are pretty cheep $
Nick
86 d150 turbo /6.
PostPosted: Sat Jun 19, 2010 7:11 am
Hi Nick,
Are these for 2.2?? 88 or 89mm? If so I would say they are a pretty good bet.
PostPosted: Sat Jun 19, 2010 7:56 am
no these actually fit stock 225 rods,like I said older(obsolete )
Nick
86 d150 turbo /6.
PostPosted: Sat Jun 19, 2010 8:15 am
Let me know if you pass.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Jun 19, 2010 8:58 am
I have three engines with TRW pistons in them. Two use the Slant 6 piston you are looking at with the head and block milled to raise compression. The heads are rather thick and I cut notches for the intake valves in one set. They weigh about the same as a stock cast piston but are much stronger. Several on this board have used them with turbos sucessfully. I just pressed the pins into the rods and they have given long service and produced good power for me.
My racing engine uses TRW pistons for a Corvair with the 7" 198 rods, also pressed in pins. The pin bores in the pistons were enlarged to use shortened Slant 6 pins. I cut pretty deep notches in them for both valves. They have also given reliable service and made good power. The Corvair pistons have the advantage of using lighter 1/16" wide rings.
PostPosted: Sat Jun 19, 2010 9:13 am
thanks for the info. I need to build another motor for a valiant I purchased and I also burned a hole in the turbo truck piston wed night beating a supercharged saleen mustang so I was hopping to hear good things about the trws
Nick
86 d150 turbo /6.
Users browsing this forum: No registered users and 15 guests
