It is currently Sat Nov 21, 2026 6:21 pm
 Post subject: Hot Floorboard
PostPosted: Sat Jun 19, 2010 2:00 pm
The floorboard near the transmission hump in my 76 Valiant seems to get overly hot....basically, right where my right foot rests while working the gas pedal.
I have some Dynamat that I can slap down there and kill the heat, but I'm more concerned about whether or not this is normal....maybe the transmission is getting too hot.
Anyone else experienced a hot floorboard?
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Sat Jun 19, 2010 5:11 pm
Bad cat?
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
 Post subject: hotfoot
PostPosted: Sat Jun 19, 2010 5:15 pm
Is the exhaust stock? Someone could have hacked in a piece too close to the floor? Headers? Beat motor mounts messing up the engine position?
I wouldn't think the trans could get hot enough to heat up your foot through an inch or more of moving air, sheetmetal, carpet and underlay/deadener?
Gotta be the exhaust pipe. Get under there and check it out.
Oh, and you do know the heater outputs right there by your feet right? Got a leaky heater box or anything?
Good luck and don't burn down your car!
rdr
madam im adam
PostPosted: Sat Jun 19, 2010 8:38 pm
Thanks for the hints.
The exhaust is bone stock....extremely stock....as in....original 1976 equipment.
Maybe I should just remove the cat.....I need to check to be sure, but I'm pretty sure it would be legal here in Texas eliminate it.
