| Hot Floorboard https://slantsix.org/forum/viewtopic.php?t=40708 |
| Author: | rustyfords [ Sat Jun 19, 2010 2:00 pm ] |
| Post subject: | Hot Floorboard |
The floorboard near the transmission hump in my 76 Valiant seems to get overly hot....basically, right where my right foot rests while working the gas pedal. I have some Dynamat that I can slap down there and kill the heat, but I'm more concerned about whether or not this is normal....maybe the transmission is getting too hot. Anyone else experienced a hot floorboard? |
| Author: | 65 dartman [ Sat Jun 19, 2010 5:11 pm ] |
Bad cat? |
| Author: | radarsonwheels [ Sat Jun 19, 2010 5:15 pm ] |
| Post subject: | hotfoot |
Is the exhaust stock? Someone could have hacked in a piece too close to the floor? Headers? Beat motor mounts messing up the engine position? I wouldn't think the trans could get hot enough to heat up your foot through an inch or more of moving air, sheetmetal, carpet and underlay/deadener? Gotta be the exhaust pipe. Get under there and check it out. Oh, and you do know the heater outputs right there by your feet right? Got a leaky heater box or anything? Good luck and don't burn down your car! rdr |
| Author: | rustyfords [ Sat Jun 19, 2010 8:38 pm ] |
Thanks for the hints. The exhaust is bone stock....extremely stock....as in....original 1976 equipment. Maybe I should just remove the cat.....I need to check to be sure, but I'm pretty sure it would be legal here in Texas eliminate it. |
