It is currently Fri May 15, 2026 10:51 am
PostPosted: Sun Jun 20, 2010 7:22 am
Hey guys just wondering which T-stat to pick, told the kid at the parts store I wanted a 180deg, and I checked the P/N after I got home, and he gave me a F@&$ing 195 WTF ??!!, Its silly hot (FL summer weather) with everyday last week hitting well over 90 out i figured 180 would be a fair compromise, but a 160 is also available, would it hurt anything to run a 160 ??? ( I also have a pretty sweet cooling fan I got from a buddy of mine from the BMW he works at so that will be installed as well)
second question, I have a cliffy 4BBl mani and was going to run the eddy carb (hey it was free and really only cost me about $23 for the rebuild kit) i wanted to run some kind of "heatsink" between the carb and mani but didn't know if I should run an aluminium spacer or a phelonic one, didn't know which would dissapate heat better, and I also saw teds aluminium plate set up, but didn't know which would be better, the plate or the spacer and which material,
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Jun 20, 2010 7:36 am
The Plate............surface area will dissipate more heat faster than a spacer
I personally use a wooden hand crafted spacer with an aluminum plate on top. Wood works better than ant thing you can buy. If you have the patience and a small jig saw it's basically free
MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Sun Jun 20, 2010 7:40 am
how thick for each, and what would you use to sel the wood ?? epoxy resin ??
-Mike
PostPosted: Sun Jun 20, 2010 8:48 am
I use a 1" wooden spacer (spray painted w/clear urethane) Krylon brand.
For the aluminum heat spacer I use 1/4 X 4" X 8". Offset it to cover exhaust manifold. MaX
1966 barracuda 360
PostPosted: Sun Jun 20, 2010 8:52 am
cool now what emp t-stat should I be running ???
PostPosted: Sun Jun 20, 2010 9:46 am
If you are running a carb I'd use a 180 in hot weather 90 to 100 degrees
In the winter 32 to 80 = 195 degrees
where it's frigid 32 on down= 200 205 210
hope this helps MaX
1966 barracuda 360
PostPosted: Mon Jun 21, 2010 3:59 pm
yea i went with a 180deg, figured the electric fan can compensate, that an I have aggressive teds fan relay write up saved,
-Mike
 Post subject: right way to go
PostPosted: Mon Jun 21, 2010 4:46 pm
Teds idea is spot -on..........keep in touch with us.......I like progress reports. Helps keep me motivated :D :D :D
regards MaX
1966 barracuda 360
PostPosted: Mon Jun 21, 2010 7:09 pm
I'll do what I can max, but it will probably end up in the ....So what did you get done on your slant today ??? section lol
-Mike
 Post subject: -
PostPosted: Mon Jun 21, 2010 9:42 pm
yes I have 180 and 195 t-stats and I switch them summer and winter.
Users browsing this forum: Google [Bot] and 33 guests
