It is currently Wed May 06, 2026 8:56 pm
 Post subject: Wiseco and K1
PostPosted: Wed Jun 23, 2010 8:59 am
Are the Wiseco Pistons and K1 connecting rods still available to anyone's knowledge?
PostPosted: Wed Jun 23, 2010 4:55 pm
Yes and the k1/wiseco thread should be a stickie
11.02 @ 120.56
Chassis dyno
PostPosted: Thu Jun 24, 2010 8:08 am
How do those connecting rods compare to the originals? Night and day?
PostPosted: Sun Jun 27, 2010 9:17 pm
They are lighter and stronger. If you are not making big HP (275+) or trying to turn more than 5500 RPM, then they are probably not needed, though.
Happy building,
PostPosted: Mon Jun 28, 2010 9:34 am
The best thing about the K1 rods is that these are 7.005 long, basically the 198 SL6 rod length. (These rods don't work in a 225, with standard SL6 pistons, you need a shorter piston)
Seeing how hard it is to find 198 con rods and the additional cost to install good bolts and have the rods reconditioned, the K1 - Wiseco "deal" is a pretty good value.
PostPosted: Mon Jun 28, 2010 11:28 am
I just bought 2 Of the pistons from them last week they have them in stock.
PostPosted: Tue Jun 29, 2010 8:10 am
Perfect! Thanks a ton!
Users browsing this forum: Amazon [Bot] and 1 guest
