It is currently Sat Nov 14, 2026 12:19 am
 Post subject: Pin connectors on HEI
PostPosted: Wed Jun 30, 2010 8:55 am
I recently pickup a combination bracket w/ coil and ECU w/heat sink out of a 1997 Blazer. IT has a part number of 12568466 on the bracket . It is a complete unit.
The problem is that it has pin connectors instead of spades. Do I assume that the pins are the same arrangement as the spade terminals? or can someone steer me in the right direction as to how this thing wires up? there are no numbers on the coil or the ECU as to what pin is what.
The coil has 3 pins with a male coil wire connector and the ecu has 4.
Has anyone wired one of these before? I don't want to go on assumptions.
Thanks in advance.
MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Wed Jun 30, 2010 12:23 pm
6 Pack Dart
Post subject: (Thu Apr 01, 2010 5:55 pm)
I am starting this conversion and need a bit of help with the coil wiring. I have the 3-pin gm coil. (Picture from Dan's write-up. Thanks for revamping that, btw.)
Everyone else seems to be using the 4 pin version. The coil has no markings as to what's what, so I have no idea which pin is A and which is C. (I figured out B on my own. ) Thanks in advance.
64 Valiant
Back to top
Fopar
Post subject: (Thu Apr 01, 2010 6:58 pm)
As you have positioned in picture left is A and right is C.
You will be better off using the older 4 pin module, you will have to trim off the fin closest to back side of the module to get it to fit. Side note the connector for the coil is not generally at parts stores (hope you got it with the rest of this unit) if not PM me for the part #
