It is currently Sat Jul 18, 2026 1:15 am
 Post subject: holley 1945 trouble
PostPosted: Sat Jul 10, 2010 5:39 pm
Car Model: 87 B150, 1970 Valiant 4-door
After a winter of remaining mostly idle with less than 1 gallon of gas in it (started up periodically and let idle, or made tool runs to my rented garage 2 blocks away), I drove my van in the spring to pick my wife up from the tire place while her tires were mounted.
I ran out of gas, bought 2 gallons in a can, started it up (w/ether) and it would not idle.
I eventually ran it long enough to burn off the worst of the winter tank swill. It still hesitated under load.
After driving at highway speeds for 5 minutes it'd stall out then only start with ether, and not run under load with the air cleaner in place.
I got it home and have not done much with it since (apart from tool runs and periodic startups).
Runs better with no air cleaner (too rich?) and hesitates when I punch it (accelerator pump?)
Could I just have gunk sticking the float and interfering with the accelerator pump function?
(it was professionally rebuilt 18 months ago, or so).
I guess I will get a rebuild kit, clean it and reassemble using just the pump cup and gaskets, leaving the balance of the kit alone.
Is there anything easier I could try? (I did run a bunch of carb cleaner through it while running, and it did improve a little for a while--nothing I know of that it can do for the accelerator pump or the float).
Any ideas?
PostPosted: Sat Jul 10, 2010 7:08 pm
Site Admin
Sounds like a good coating of shellac. Tear it down, clean it up, and rebuild it like it's a virgin never been touched carb. No sense having spare parts lying around. :wink:
CJ
Users browsing this forum: Amazon [Bot], Bing [Bot] and 6 guests
