It is currently Wed Oct 14, 2026 3:22 pm
PostPosted: Sun Jul 11, 2010 2:37 pm
I have a 1965 valiant slant six with automatic transmission. Today, the forward three gears stopped working unless I rev the engine to over 1500 rpm, but, the transmission works fine in reverse. I was told that it might be the forward pump in the transmission and it would need a complete tear down to fix. Does this sound like the case? Should I try to find a used transmission or have this one rebuilt?
Advice?
PostPosted: Sun Jul 11, 2010 3:03 pm
I have had a similar problem in a transaxle. It got rebuilt. Had something to do with the clutches being messed up, so they didnt grab until they had a fair amount of pressure. It's a teardown type of repair.
What's that fuzzy blue thing being hurled this way?
::stick::
BOOSH!!!
PostPosted: Mon Jul 12, 2010 2:23 am
The rear clutch is used for all forward gears so a wild guess would be that there is some problem with the rear clutch, but there are other reason also.
The accumulator might be sticking, hydraulic pressure might be too low or valve body leakage or something else.
Have you checked the oil level in the tranny ?
PostPosted: Mon Jul 12, 2010 4:54 am
lancer61:
[quote]The rear clutch is used for all forward gears so a wild guess would be that there is some problem with the rear clutch, but there are other reason also.
Have you checked the oil level in the tranny ?[/quote]
No movement in forward positions:
Line pressure too low.
The only two quick, and easy fixes are
low fluid level, or possible shift linkage maladjustment.
All other mechanical causes require disassembly and inspection.
Look up in your factory service manual under transmission; “Service Diagnosisâ€￾, for the full scoop.
