It is currently Sat Nov 21, 2026 7:11 am
 Post subject: Lifting one side of car
PostPosted: Thu Jul 08, 2010 6:57 am
Is it OK to lift one side of an A-body so that both right tires are in the air?
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Thu Jul 08, 2010 8:11 am
I used to do this to my '66 Dart all the time because I couldn't get a jack under the K-member. If you jack from the rear of the front subframe near the torsion bar cross member you'll eventually get both wheels up. Be careful!
Users browsing this forum: Amazon [Bot] and 2 guests
