| A Couple More Turbo Questions https://slantsix.org/forum/viewtopic.php?t=4113 |
| Author: | DusterNut [ Mon Sep 02, 2002 5:39 pm ] |
| Post subject: | A Couple More Turbo Questions |
I am going to turbo my Duster with a 225/4-spd-OD. So im still not sure in a few areas. -I remember hearing that a BB Mopar fuel pump will fit the slant if i swap the slant arm into the the BB pump, is this true? I think i would feel better having a boost refrenced BB pump, this way i could have 3/8 line the whole way. -Is the MSD BTM absolutely necessary? If i retard the timing 5-7 degrees will i be ok? -Should i keep my dual 2" Flowmater exhaust, and run a y-pipe into the turbo, or sell it and run a single 3" into a Magnaflow muffler, with dual 2.5" outlets? The flowmasters are a little too loud actually, i dont want to get negative attention from the law enforcement:) Thanks, Tom B tommyb1515@aol.com |
| Author: | Matt Cramer [ Mon Sep 02, 2002 7:13 pm ] |
| Post subject: | Re: A Couple More Turbo Questions |
: I am going to turbo my Duster with a : 225/4-spd-OD. : So im still not sure in a few areas. : : -I remember hearing that a BB Mopar fuel pump : will fit the slant if i swap the slant arm : into the the BB pump, is this true? I think : i would feel better having a boost refrenced : BB pump, this way i could have 3/8 line the : whole way. I tried this, but after getting the fuel pump off and taking a look at them it looked like a bit more work than I wanted. So I just put an electric pump with a boost referenced pressure regulator on there instead. It certainly appears possible, but I wasn't sure how to remove the pin that was holding the arm in place easily; the only thing I could think of was drilling it out. If you want the BB fuel pump, I could sell you the brand new one I bought for the conversion. : : -Is the MSD BTM absolutely necessary? If i : retard the timing 5-7 degrees will i be ok? I've heard of turbo setups being done without a pressure retard, but the BTM will be helpful in making more power than with no system to retard timing under boost. : : -Should i keep my dual 2" Flowmater : exhaust, and run a y-pipe into the turbo, or : sell it and run a single 3" into a : Magnaflow muffler, with dual 2.5" : outlets? The flowmasters are a little too : loud actually, i dont want to get negative : attention from the law enforcement:) : : Thanks, Tom B I don't have flowbench data for the Flowmasters or Magnaflow, but I'm guessing two mufflers will be better than one, and the Flowmasters should certainly work. If the Magnaflow is a good straight through design, chances are neither muffler setup will offer a performance gain. Matt |
| Author: | Dan M. [ Tue Sep 03, 2002 6:27 am ] |
: -I remember hearing that a BB Mopar fuel pump : will fit the slant if i swap the slant arm : into the the BB pump, is this true? I think : i would feel better having a boost refrenced : BB pump, this way i could have 3/8 line the : whole way. I went this route myself, but I'm a little disapointed with the results. Next week I'm installing a Carter electric pump with a NOS vacume/boost refrenced regulator. My fuel pressure is a little weak at idle when I first start the car, takes about half a minute to come up, and I seem to run out of pressure at about 80 mph if I jump on it. : : -Is the MSD BTM absolutely necessary? If i : retard the timing 5-7 degrees will i be ok? I did the turbo first without the MSD BTM. About a month later I added it. Huge differance all the way around! (especially at low rpm) : : -Should i keep my dual 2" Flowmater : exhaust, and run a y-pipe into the turbo, or : sell it and run a single 3" into a : Magnaflow muffler, with dual 2.5" : outlets? The flowmasters are a little too : loud actually, i dont want to get negative : attention from the law enforcement:) A turbo has a good deal of muffler efect on the exhaust. I ended up just doing 2 1/2" single pipe with a large stainless steel resonator off of a Mitabitchy. You'll probably be OK with the Flomasters. Dan M. slantedsix225@aol.com |
| Author: | andrew wagner [ Tue Sep 03, 2002 7:03 pm ] |
| Post subject: | Re: A Couple More Turbo Questions *PIC* |
I ran a flowmaster on mine for a while. It works fine and I really liked the sound, but a straight thru muffler is the way to go with a turbo car. I also have the msd btm and I would not be with out one! andrew wagner Quote:
: : I tried this, but after getting the fuel pump : off and taking a look at them it looked like : a bit more work than I wanted. So I just put : an electric pump with a boost referenced : pressure regulator on there instead. It : certainly appears possible, but I wasn't : sure how to remove the pin that was holding : the arm in place easily; the only thing I : could think of was drilling it out. If you : want the BB fuel pump, I could sell you the : brand new one I bought for the conversion. : : I've heard of turbo setups being done without a : pressure retard, but the BTM will be helpful : in making more power than with no system to : retard timing under boost. : : I don't have flowbench data for the Flowmasters : or Magnaflow, but I'm guessing two mufflers : will be better than one, and the Flowmasters : should certainly work. If the Magnaflow is a : good straight through design, chances are : neither muffler setup will offer a : performance gain. : : Matt
